pop wrangle velocity from sop
I attached simple file to illustrate my question.
I want to emit particles only once from each point,
but later add velocity over time with color animation.
I do all of this with pop wrangle from SOP, because initial vel dont work for me
in this case. The problem I have is, that this velocity from
pop wrangle is constant, it work for all frames.
I want this velocity to be only initial velocity.
I would like to add vel on begging and later the gravity to take over
in natural way. Any ideas.
vel_pop_test_01.hip
In the source node, create a just born group under the Birth tab.
This will put every particle being born on current timestep in this group.
Set a wrangle node to operate on that group, and use a vexpression to set velocity.
