Problems with Real Flow extensions and H7 WinXP
lisux
Hi list, and specially Mark Story, this message is specially for him.
Finally i've upgraded to H7, so forget the problems with H 6.1 and Real Flow extensions, thanks for all.
Now i've using the plugin for H7.0.192 (Non-Comercial) in Win XP SP2, i've only used the RF Geo Import, for particles and meshes it works fine, but for SD files i can't load it. In one case houdini crashes ,and in others i get a warning saying that in this version only one object is supported.
What are the limits for the SD importer, this limits will be solved?
Thanks Mark again for your excelent work.
P.D: i hope i can test your extensions very soon with RH 90.
