squardis Posted May 29, 2015 Share Posted May 29, 2015 (edited) Hi, Im trying to copy and paste relative refference from e.a. out\merge\render button to a master_ctrl ( null ) on \obj level...but i dont get any response when I hit the botton. also i get an error when i try to drag the button into my Parameter Interface editor. it says: Problems While creating some requested parameters: Node is outside subnet: /out/merge1/excecute How can i fix this? thnx Edited May 29, 2015 by squardis Quote Link to comment Share on other sites More sharing options...
H2O Posted May 29, 2015 Share Posted May 29, 2015 Hi Here the solution for the "error" problem. In your Parameter Interface Editor, you have to uncheck the "Forbid Linking Parameters from Outside this Subnet". (look at the joined picture) cheers 4 Quote Link to comment Share on other sites More sharing options...
squardis Posted May 29, 2015 Author Share Posted May 29, 2015 Thnx H20! Awsome! Quote Link to comment Share on other sites More sharing options...
