How to set velocity of RBD objects to 0 at every time step?
magneto
I animated the transform/shape of my RBD objects in SOPs and then import them into DOPs as a RBD packed object but the parts are flying before they even touch each other. I assume it's because Houdini assigns them velocity in DOPs based on the transformation direction.
Is there a way to prevent that? Or should I just reset velocity to 0 every timestep? If so, how can I do that?
