ramp from HOM
freaq
trying to control a randomness by a ramp parameter
so an artist can control what spawns more often and less
my idea is to take the curve, integrate it (or via numpy .cumsum())
and then index that value.
but apparantly this is not so easy in houdini,
some pointers anyone?
ps: also weird:
when storing a ramp as a variable the ramp cannot be adressed:
this works:
hou.parm('/obj/lot1/distribution2').eval().lookup(0.7)
this does not:
dist = hou.parm('/obj/lot1/distribution2').eval()
dist.lookup(0.3)
which makes it very inconveniant to do things like integrate etc.
very nasty :(
not really sure what exactly you are doing and if you really need to integrate the samples as that is usually not necessary for common ramp defined distribution control, but
dist.lookup(0.3)
works for me, you can as well try .evalAsRamp() if that makes any difference
here is the full integration example, seems to work fine
import numpy
parm = hou.parm('/obj/lot1/distribution2')
ramp = parm.evalAsRamp() # even though parm.eval() works as well
nsamples = 10
samples = [ramp.lookup(s/(nsamples-1.0)) for s in range(nsamples)]
integratedsamples = list(numpy.cumsum(samples))
print "ramp raw samples  : %s" %samples
print "integrated samples: %s" %integratedsamples
Edited by anim
