POP Wrangle expression question
Hey guys,
I have a question about pop wrangle if else statement. I'm trying to record the frame number that when the particle enter a
group.
In the old pop using the attribute node
if($ENTER_GROUP == -1, $F, $ENTER_GROUP)
it works however im trying the new pop n with its POP wrangle it kind of not working. Im not really sure what i did wrong
i@enter_group = -1;
if (@enter_group == -1) {
    @enter_group = @Frame;
} else {
    @enter_group = @enter_group;
Thanks u guys for your help in advance :)
here is the example
but essentially the code is:
// this code is run only on particles in desired group
float @enter_groupf = -1; // default value for initialization of enter group frame (if you sim in negative frames, make this lower than your start frame)
if (f@enter_groupf == -1) //if current value is still at default
    f@enter_groupf = @Frame;  // set it to current floating frame
pop_enter_group_frame.hip
Edited by anim
