Setting material groups
I have a model with UVs and surface IDs (polygon groups) from Modo. When I import it, Houdini generates UV islands for each group and adds a shop_materialpath appending the group name, e.g, "/shop/wall" as a polygon attribute.
I would like to use either the island number or the shop path in the group parameter in a material node to apply different materials. I know its pretty straightforward but haven't been able to create a group based on either one. I would prefer to base the grouping on the UV islands but knowing both would be good.
If someone can point me in the right direction, much appreciated.
OK, got it. I can use connectivity and partition to create the groups by material names after some clean-up with a prim wrangle. HIP file attached in case it helps anyone else. I haven't sorted out how to identify the material group by UV island index but will post it if i do.
Kevin
