what is the different to get orient attribute with look at and double
not sure what answer you are looking for
both can be used to compute a rotation matrix, and both can even give you the same rotation matrix if you understand what they do, they are just functions to serve you to get to some result
while lookat() is specific about the orientation of the axes within the matrix to correspond to inputs, with double cross product you need to know what vectors you are using for which axes and as well you need to handle normalization and matrix assembly, it's like building your own lookat() function using lower level math
(lookat() probably uses cross products to compute matrix as well)
there is plenty of other ways how to compute rotation
like you can as well use maketransform() to compute rotation matrix from 2 vectors
Edited by anim
