An Issue with Import Arrtip in H14
Hey guys
Im trying to isolate a deformed object using a vop sop but it did not work with me well.
As you will see in photos that i did the deformed on the ground
but now i want to isolate the deformed geometry only but comparing the length from the position using vop sop
In h13 i was Importing the P the comparing it with the current P the export it as attribute , but in houdini 14 its not working with me at all :(
Any help please :)
Here is the rock animation seq:
    http://www.mediafire.com/download/g39bvlxausvzk0i/RockAnimation.rar
Deformed_Geo.hip
Geo_Marked.rar
post-11123-0-43882000-1436631647_thumb.j
post-11123-0-09814100-1436631651_thumb.j
post-11123-0-60213800-1436631654_thumb.j
Edited by AhmedSaady
There was actually a couple of things wrong. First the getattrib was not provided with any ptnum to work with and was referring to the first input of the pointvop which is the same as the global variables. Then you were using addattrib to bind values using the "default value" input when you should only use it to create the local variable.
I would suggest you use wrangle nodes for this type of work, much faster and much simpler then what you are doing here.
if(@P==point(1,"P",@ptnum)){
    removepoint(0,@ptnum);
Alex
Deformed_Geo_fixed.hipnc
Alex
Hey Alex
well , you are right it is much faster and it solve the issue also
and for the original setup it was close but the issue was from import the P from second input not from first one and this is what is look like:
Then you just delete based on $DEFORMED value which you export from it.
post-11123-0-32579600-1436642617_thumb.j
