ObiNon Posted July 11, 2015 Share Posted July 11, 2015 I am sure I am just doing something incorrectly, but I am attempting to work through an older cmivfx course and i cannot seem to reproduce one of the lessons. It was created in an older version of houdini. Anyway ... the network is supposed to find the nearest point on a piece of geometry given a query object. It uses 'pcopen' and 'while loop'. I stripped it down as to not get in hot water with cmi ... but here is a .hipnc that has the working network (colored green) and my attempt at recreating it (colored red). If anyone can tell me what I did wrong that would rock. there is a custom marker that will display the 'nearptnum' attribute so you don't have to drill to the spreadsheet. Thanks a ton ... M vopsoppcopenbad.hipnc Quote Link to comment Share on other sites More sharing options...
SSFX Posted July 11, 2015 Share Posted July 11, 2015 (edited) You are trying to set an attribute value with an addattrib node, it won't work as you are only defining the default value of the attribute. To set an attribute value use either the setattrib node or the bind export node. vopsoppcopenbad_fixed.hipnc Edited July 11, 2015 by SSFX 1 Quote Link to comment Share on other sites More sharing options...
ObiNon Posted July 15, 2015 Author Share Posted July 15, 2015 You are trying to set an attribute value with an addattrib node, it won't work as you are only defining the default value of the attribute. To set an attribute value use either the setattrib node or the bind export node. Thanks ! I will check it out right away. Quote Link to comment Share on other sites More sharing options...
