VEX, PointClouds - Changing attibute data
Whatsinaname
In my scene, there are lots of similar objects, consisting of points.
The points have an attribute, indicating to which object they belong (object_ID).
If any of those points collides with another object in the scene, the pscale of those points should be set to 0.
The collision test etc works just fine, I only don't get how to set the object_ID, like:
A) get the object_ID for the points inside the collision volume (works)
B ) get all other objects with the same objectID and set their pscale to 0.0 (doesn't work)
Here's what I'm doing:
float sdfCheck = volumesamplefromfile(1,"surface"@P);
if(sdfCheck < 0)
     // change color to visually identify points inside collision volume
     @Cd = {1,0,0};
      //open a pointcloud and check for the object_ID value
     int handle = pcopen(0,"P",@P, 20000, 100);
     int ref_object_id;
     float target_pscale = 0.0;
     while(pciterate(handle))
          pcimport(handle,"object_id", ref_object_id);
          //check if the object_id at the pointcloud point is the same as the object_id of the point inside the collision volume
           if(i@object_id == ref_object_id)
                   // doesn't work as channel is not writable...??
                   pcexport(handle, "pscale", tgt);
pcexport doesn't seem to be the right idea in that context, but what should I be doing instead? Thanks in advance for any ideas!
Edited by Phlok
you can as well use findattribvalcount()/findattribval() combo to loop through all points with certain attrib value and set their pscale instead of checking all points for matching object_id yourself
