Random carve with copy stamp (noob alert)
Werner
I have a curve that was copied a couple of times down in Y, and want to carve the length randomly with copystamp.
I'm missing something because each copy gets exactly the same carve length.
this is what I have in stamp
Variable 1 = C        Value 1 =    rand($PR+123)
On the carve I have the normal stamp function   stamp("../copy2","C",0)
How can I randomise the values per copy?
Hey Werner
For a better random result you might want to change your
 rand($CY+123)
to something like this
rand($CY*0.123)
especial if you use the $CY in other rand() functions as well.
By multiplying the value in each rand() with a different number instead of adding a value you decrease the change of getting the same result when using the rand function multiple times.
Hey Werner
 rand($CY+123)
rand($CY*0.123)
Thanks Maurits,
I will give it a go.
