cojoMan Posted July 18, 2015 Share Posted July 18, 2015 (edited) To start off...aparrently, FOREACH and SOLVER don't work well together... I had a perfectly working system I only tested on a point that did a lot of crazy stuff, but it started like this : - I have an attribute SINE - SOLVER SOP - merge input with previous, then after the solver, timeshift end - so now I have 1 point per each frame with the attribute's value at that frame - etc etc processing It all rested on having the initial sampling for each frame of the Sine attribute above in individual points at frame 1. Now, all said and done, the system worked and all was nice and easy - time to apply this to multiple points. So FOREACH, include the above system inside (points, merge result) - and... fail. After many searches around here and in the help - apparently SOP SOLVER inside a FOREACH doesn't play nice at all. Or simply doesn't play. My system kinda rests on "plotting" the said SINE attribute through the whole timeline with smth else that a solver now... - I thought of bringing the attribute in a CHOP, then reading it back, but I haven't figured that one out, or if it would work. - I tried delete-copyStamping the initial points, but that doesn't seem to do it either So at the moment I am trying to process this initial point with the attribute through a wrangle node, using the CHF function - that can get a channel's value@frame X. So per point, I am reading the current point's attribute in a spare parameter to have it in a channel, then using the code bellow, cloning the point per frame, and storing the channel's value at that frame in the point - but for some reason this fails miserably as well... CHF seem to be reading a different value per frame and writing it, but side by side, not the same value. float @test; for (int i=1; i<=100; i++) { int pt = addpoint(geoself(), i); setpointattrib(pt, "test", i , chf("attrib",i)); } Scene attached. Thanks for your help. sampleAttribute.hip Edited August 14, 2015 by cojoMan Quote Link to comment Share on other sites More sharing options...
ChristopherC Posted July 18, 2015 Share Posted July 18, 2015 I never used the `chf` function in VEX and have no idea of how it works nor what are its pitfalls but it somehow feels a bit hacky to (indirectly) retrieve attributes this way. There's anyways simpler ways to do this, I believe. In the attached scene you will find 2 methods to “plot” the sine attribute onto your 100 points—one relying on a simple combination of `ForEach` and `TimeShift` node, which seems the most intuitive of the 2, and the other one using CHOPs since you mentioned it. sampleAttribute-Edit.hipnc Quote Link to comment Share on other sites More sharing options...
cojoMan Posted July 18, 2015 Author Share Posted July 18, 2015 I really didn't know WHAT to search for to plot via chops, but so happy I found out HOW (chopci ? never heard of it before...) and I could beat myself over the head for the oh so obvious foreach+timeshift drill. thanks a lot Chris ! Quote Link to comment Share on other sites More sharing options...
acey195 Posted July 19, 2015 Share Posted July 19, 2015 chf() in VEX is not the same as ch() in expression language in VEX ch() is asking for a generic parameter chf() is asking for a float parameter chi() is asking for an int parameter chs() is asking for a string parameter 1 Quote Link to comment Share on other sites More sharing options...
