convert connected segments into a nurbs
mrWolf
Is there any sop node to convert an open polyline into *one* NURBS curve ?
This is the poly object I am starting from :
post-1409-0-98038200-1437703398_thumb.pn
Each segment, forming the polyline, is an open polyline that connects two points.
There are no overlapping points.
The topology is very clean and it contains all the info required to rebuild a NURBS but I cannot find any SOP node that achieves this.
I tried "Convert" sop , forcing the conversion to NURBS curve, but of course it creates a ton of tiny NURBS curves , each one matching the original segment.
I am sure I am missing something very obvious
