Anatol Posted July 27, 2015 Share Posted July 27, 2015 (edited) Hi guys. I'm trying to get point rotation around local axis (around local Y axis) I need to export points in Maya later, so I can't use copy sop for stamping. If I use transorm sop with Copy Stamping I can rotate Objects along local axis, but if I'm trying to edit rot and orient point attributes points are rotating in worldspace (around world XYZ) not along local axis. If I use orient attribute points are aranged in worlspase, not along normal. Can sombody help with that, please? ps I found Make Instance Transofm Vex node, but 'Ive got no Idea how to use it >__> point_rotation_001.hip Edited July 27, 2015 by Anatol Quote Link to comment Share on other sites More sharing options...
Anatol Posted July 27, 2015 Author Share Posted July 27, 2015 (edited) Found nice topic http://forums.odforce.net/topic/19482-orient-rot-n-up-v-etc-instance-rotation-question/ dancing teapots Looks really close to that what I'm looking for. Now braking my head on this (quaternions, poly frame etc . even if point has N attribute network isn't working without polyframe ) dancing_teapots.hip Edited July 28, 2015 by Anatol Quote Link to comment Share on other sites More sharing options...
