problems in packing geometry
vijaykumar
hi guys,
             i have fractured a box and packed it using assemble sop.. if i create primitive attribute using connectivity sop after packing and unpacking it the outer surface has a different primitive number unless i leave the inside group blank or with other names in assemble sop.. what have i done wrong.. also if i use the connectivity sop before assemble sop everything works fine.  please check the sample file..packtest.hipnc
