Look through alembic camera in H
Hello, this might be a silly solve but I found myself stuck in a Houdini scene trying to look through an imported camera from Maya (I'm using an alembic file). In /OBJ I have made both an alembic transform and an alembic archive node, selecting the alembic file in File Name and the actual camera in the Object Path.
From here I cannot actually see the camera, move it or rotate it. There also isn't an option for a camera in the top right-hand side in the viewport.
Any insight would be greatly appreciated!
Hi Nico,
Easiest way to import an alembic camera is through the file menu. Go to File/Import/Alembic_scene and choose your file from there. The camera should import as you expect then and show up in the top right-hand side in the viewport as well.
Hope that sorts out your problem.
