Problem compiling in Mac 10.8
Hello I am getting some issues compiling some code in a Mac using Mac OSX 10.8.5.
I have modified the command line from the Makefile t use clang++ rather than g++. And this is the result:
/usr/bin/clang++ -DIGNORE_HDK_DEPRECATIONS -std=c++11 -mmacosx-version-min=10.8 -c -DVERSION=\"13.0.687\" -D_GNU_SOURCE -DMAKING_DSO -DMBSD -DMBSD_COCOA -DMBSD_INTEL -arch x86_64 -DAMD64 -fPIC -DSIZEOF_VOID_P=8 -DFBX_ENABLED=1 -DOPENCL_ENABLED=1 -DOPENVDB_ENABLED=1 -DSESI_LITTLE_ENDIAN -DENABLE_THREADS -DUSE_PTHREADS -D_REENTRANT -DNEED_SPECIALIZATION_STORAGE -DGCC3  -I/Library/Frameworks/Houdini.framework/Resources/toolkit/include -Wall -W -Wno-parentheses -Wno-sign-compare -Wno-uninitialized -Wunused -Wno-unused-parameter -Wno-deprecated -Wno-reorder -O2  -DMAKING_DSO -DUT_DSO_TAGINFO='"3262197cbf0248162fa92d8b523894b22741d6f1c36287fa6d9cd0561769ee812b972985db32267a5946daed23da230a4b8fa057efd0e95546162de86dff91b64ea845c28ce66394a3268d0847ba11fce917cff09fe39b68fc965e0d150fef40f45de44cf558"' SOP_MyCoolTool.cpp -o SOP_MyCoolTool.o
In file included from SOP_MyCoolTool.cpp:54:
In file included from /Library/Frameworks/Houdini.framework/Resources/toolkit/include/OP/OP_Director.h:31:
In file included from /Library/Frameworks/Houdini.framework/Resources/toolkit/include/OP/OP_OTLManager.h:26:
/Library/Frameworks/Houdini.framework/Resources/toolkit/include/OP/OP_OTLLibrary.h:90:41: error: invalid suffix on literal; C++11 requires a space between literal and identifier
      [-Wreserved-user-defined-literal]
#define OTL_MODULE_VEX_SECTION          "Module"OTL_VEX_SECTION_SUFFIX
/Library/Frameworks/Houdini.framework/Resources/toolkit/include/OP/OP_OTLLibrary.h:91:41: error: invalid suffix on literal; C++11 requires a space between literal and identifier
#define OTL_MODULE_VFL_SECTION          "Module"OTL_VFL_SECTION_SUFFIX
In file included from SOP_YAPS.cpp:62:
./YAPS_Util.h:51:16: warning: 'reflectVector' has C-linkage specified, but returns user-defined type 'UT_Vector3' (aka 'UT_Vector3T<float>') which is incompatible with C
      [-Wreturn-type-c-linkage]
    UT_Vector3 reflectVector (const UT_Vector3 &incident, const UT_Vector3 &normal);
SOP_YAPS.cpp:3189:9: warning: unused variable 'indent' [-Wunused-variable]
    int indent = 4; // This is temporary
2 warnings and 2 errors generated.
The code compiles correctly in Linux using gcc.
Using g++ in Mac get more warnings but the same two errors.
Any idea if I need to use a special flag for clang to compile this?
Thanks
