Guest xionmark Posted November 28, 2004 Share Posted November 28, 2004 Hi, This is a problem that's been plauging me for a long time, more an annoyance than a bug, but I'd like to be able to fix it. What happens is that some fields in the GUI are not always "active" when they should be after the OP has been first created or when the .hip file is first opened up. I see that the disableParms() function is called, usually at least 2 times upon the creation of the OP or when opening the .hip file. In this example, notice the "Start/End" field is disabled: After toggeling the "Animated" menu above it, the "Start/End" field then becomes active. The disableParms() function starts by disabling all parms, then based on the state the SOP is in will enable a selection of the parms, please see the code fragment below. What's weird is this is the function that gets called when the user changes any GUI parm, yet it the parms aren't always set correctly when disableParms() is called in those 2 circumstances, adding a new OP and when first opening the .hip file. Any ideas? Suggestions? Thanks! --Mark unsigned changed = 0; // First turn them all off for(int i=0; i < 28; i++) enableParm(i, 0); // If we're writing an SD file if(!mySD_BIN) { // change the state of the Start/End GUI widget if(myStaticAnim) { changed += enableParm(4, 1); } else { changed += enableParm(4, 0); } changed += enableParm(3, 1); // non-animated/animated changed += enableParm(7, 1); // obj color changed += enableParm(8, 0); // tex filename (not yet implemented) changed += enableParm(9, 1); // apply object transforms } // else we're writing a particle BIN file else { changed += enableParm(3, 0); // non-animated/animated // start/end (particle exports are always animated) changed += enableParm(4, 1); // start/end changed += enableParm(10, 1); // fluid name changed += enableParm(11, 1); // fluid type changed += enableParm(12, 1); // FPS changed += enableParm(13, 1); // scene scale changed += enableParm(14, 1); // radius changed += enableParm(15, 1); // pressure min changed += enableParm(16, 1); // pressure max changed += enableParm(17, 1); // pressure avg changed += enableParm(18, 1); // speed min changed += enableParm(19, 1); // speed max changed += enableParm(20, 1); // speed avg changed += enableParm(21, 1); // temp min changed += enableParm(22, 1); // temp max changed += enableParm(23, 1); // temp avg changed += enableParm(24, 1); // emitter pos changed += enableParm(25, 1); // emitter rot changed += enableParm(26, 1); // emitter scale } // Always on enableParm(0, 1); // GUI switcher enableParm(1, 1); // fname enableParm(2, 1); // SD/BIN enableParm(5, 1); // echo to console enableParm(6, 1); // write file if(DEBUG > 0) cout << "disableParms()-changed: " << changed << endl; return changed; } Quote Link to comment Share on other sites More sharing options...
edward Posted November 28, 2004 Share Posted November 28, 2004 disableParms() gets called for every parm change because one might want to disable/enable parameters based on the values of other parameters. So if those other parameters change, then you would want to know about them. You're using these member variables in the disableParms() method which is likely to be a bad idea. I'm guessing that you're only assigning them in your cookMySop() method which might get called AFTER disableParms(). Or worst yet, your sop hasn't cooked yet and so they contain garbage values. Try re-evaluating the parameters in your disableParms() to determine what should be enabled. Quote Link to comment Share on other sites More sharing options...
Guest xionmark Posted November 28, 2004 Share Posted November 28, 2004 You're using these member variables in the disableParms() method which is likely to be a bad idea. I'm guessing that you're only assigning them in your cookMySop() method which might get called AFTER disableParms(). Or worst yet, your sop hasn't cooked yet and so they contain garbage values. Try re-evaluating the parameters in your disableParms() to determine what should be enabled. 15177[/snapback] Hi Edward, The member variables get initialized through the constructor, they're always good values. That's why I find it strange some parameters aren't always enabled when I would expect them to be. I've checked the return value of the various enableParm() calls too. The thing is, it's not consistent ... yet the values that I monitor from the disableParms() calls are consistent. --Mark Quote Link to comment Share on other sites More sharing options...
edward Posted November 28, 2004 Share Posted November 28, 2004 The member variables get initialized through the constructor, they're always good values. That's why I find it strange some parameters aren't always enabled when I would expect them to be. I've checked the return value of the various enableParm() calls too. 15182[/snapback] I don't know then. Perhaps you should only call enableParm() once per parameter within disableParms(). Quote Link to comment Share on other sites More sharing options...
George Posted November 30, 2004 Share Posted November 30, 2004 Also, I'm not sure if it will help with your update problem, but I would use the version of enableParm that uses the token rather than the parm index. It may expose a hidden index problem? Quote Link to comment Share on other sites More sharing options...
Guest xionmark Posted November 30, 2004 Share Posted November 30, 2004 Also, I'm not sure if it will help with your update problem, but I would use the version of enableParm that uses the token rather than the parm index. It may expose a hidden index problem? 15203[/snapback] Hi, That's a good idea, I'll try it this evening. Thanks! --Mark Quote Link to comment Share on other sites More sharing options...
