Ocelote Posted October 5, 2015 Share Posted October 5, 2015 Hi everyone! I`m trying to scatter some points with their density based on a filtered image (img/comp1). I've tried the expression "op:/img/comp1" in two different nodes (attribute from map and the scatter node) and although I'm not getting any errors, this method is not working. What's is the right workflow for importing composited images in geometry level? Thanks a lot in advance! Quote Link to comment Share on other sites More sharing options...
Ocelote Posted October 5, 2015 Author Share Posted October 5, 2015 Nevermind! It's working...I had some weird visualisation problem. Quote Link to comment Share on other sites More sharing options...
Mandrake0 Posted October 5, 2015 Share Posted October 5, 2015 just as a hint..sometimes you need to use opfullpath: http://www.sidefx.com/docs/houdini14.0/io/op_syntax Quote Link to comment Share on other sites More sharing options...
