RonaldAZ Posted October 13, 2015 Share Posted October 13, 2015 Hi! I have used a VDB analysis to calculate the curl values of a FLIP fluid, how will I go about extracting the curl values and go about using the curl values of every point in the flip fluid? Thanks! Ronald Quote Link to comment Share on other sites More sharing options...
RonaldAZ Posted October 13, 2015 Author Share Posted October 13, 2015 (edited) update..so I managed to get the separation of the points but i am not sure if I am doing it the right way. Is this the right way of doing it? Thanks! Edited October 13, 2015 by RonaldAZ Quote Link to comment Share on other sites More sharing options...
Guest tar Posted October 21, 2015 Share Posted October 21, 2015 In H15, the new particlefluidsurface node uses vdb_curl. Maybe it helps. i.e. /particlefluidsurface1/FILTER Quote Link to comment Share on other sites More sharing options...
