dswillows Posted October 14, 2015 Share Posted October 14, 2015 Hi all -It seems that none of the Fuse points options in the Extrude SOP has any effect- I recall the fuse points option, when set to "clamp all points", would clamp the edge that's extruding away from the source (green in top view) when that leading edge(red) encountered another expanding edge. When functioning & the extrusion continued, the setting would result in a poly similar to the blue line in bottom view. Am I missing something? D Quote Link to comment Share on other sites More sharing options...
dswillows Posted October 15, 2015 Author Share Posted October 15, 2015 Ok seem I forgot to add attachments- please see below,D extrude_fuse_points.hipnc Quote Link to comment Share on other sites More sharing options...
