Material Stylesheet Attach Material to Subobjects from Agents
Hi guys!
I'm having problems using the new Material Stylesheets..
This is my current geometry setup:
/OBJ/GEO NODE --> (multiple) GEO NODES
for example:
/obj/male_01/hair
/obj/male_01/body
/obj/male_01/shoes
Now I want to assign a material to the shoes of male_01 agent, but I cant get it to work in any way.
post-7872-0-15661900-1445866871_thumb.pn
So when I use the packedit node I cant see further down my agent's root name, maybe this could be the problem?
post-7872-0-92221400-1445866879_thumb.pn
I believe you're missing a level in the hierarchy - the top level target is the agent primitive(s) you want to affect, then the next sub-target is the agent shape, and the third sub-target is the primitives in the shape's geometry.
I got it working allready, it seems that my sub geometry are not named the way they should.
Instead; they are named 1, 2, 3, 4, 5 and 0 is the agent itself for some reason.
post-7872-0-66816200-1445959795_thumb.pn
Is there a way to check what the sub names are from an agent?
Uunpacking does show the names, neither does the packedit SOP.
Sorry I made a mistake with my last post, this does not actually work!
This was working by accident, would you like to explain a little bit more what with the agent hierarchy please?
Any way to see this hierarchy? Its really hard to find in the documentation.
