sibarrick Posted December 11, 2004 Share Posted December 11, 2004 Hi all, I thought I'd give Linux a try on my laptop since I had to reinstall the operating system anyway. Everything was going fine until I installed Houdini and tried to use the help. First off nothing happened, no help. The shell reported hbrowser had crashed or not started, can't remember which. Then I found I couldn't browse the internet any more nor could I browse anything on the machine. Houdini seems to have totally wiped out konquerer. Not knowing much about Linux I gave up and rebooted, that didn't help and now Houdini won't run any more either. In the end I rebooted into windows and came here to look for help. Wasn't sure what flavour of Linux to use so I went with Mandrake 10.1, since a mate at work had a copy already burned on DVD, it comes with KDE3.2. Any ideas gratefully recieved, up until that point I'd been very happy with the whole Linux thing ( apart from not being able to play DVD's everything seemed peachy ) Quote Link to comment Share on other sites More sharing options...
michael Posted December 11, 2004 Share Posted December 11, 2004 not much help...but I think the new help system is all java stuff...so I guess you could make sure that you have java running right.... stupid java...I hate you. Quote Link to comment Share on other sites More sharing options...
sibarrick Posted December 12, 2004 Author Share Posted December 12, 2004 Well I installed all the java modules I could find and still no joy. Then found that the houdini_setup_bash file looks for the wrong version of java so changed that, still no joy Then installed tcsh and ran houdini_setup and that did the trick. Help now working.... Quote Link to comment Share on other sites More sharing options...
