DocWhite Posted November 9, 2015 Share Posted November 9, 2015 (edited) Hello, what I would like to do is very simple, just for an exercise. I would like to run Houdini from a Python script using the hou module. What I am trying to get working is something like: import sys import subprocess sys.path.append('/opt/hfs15.0.244.16/houdini/python2.7libs') import hou hou.hipFile.load(file_name='/home/ramon/hello.hipnc') sf_geo = hou.node('/obj').createNode('geo') But I get no UI. I could do subprocess.Popen(['houdinifx', '/path/to/hipfile.hpnc']) but it creates deatached from the python script. Maybe should I create it first through shell (subprocess.Popen) and then load it using hou.hipFile? and start playing with it inside the python script? I would like to have a self-contained example. Just a python file that the user just runs like python script.py no more. Thanks and sorry for the stupid question. EDIT: I think I found out what I was looking for... haha... now i can compile vfls using Popen subprocesses and import them afterwards and doing everything in a self-contained file. cool. import sys import subprocess sys.path.append('/opt/hfs15.0.244.16/houdini/python2.7libs') import hou hou.hipFile.save(file_name='/home/ramon/hello.hipnc') hou.hipFile.load(file_name='/home/ramon/hello.hipnc') sf_geo = hou.node('/obj').createNode('geo') hou.hipFile.save(file_name='/home/ramon/hello.hipnc') subprocess.Popen(['houdinifx', '/home/ramon/hello.hipnc']) Edited November 9, 2015 by DocWhite Quote Link to comment Share on other sites More sharing options...
asnowcappedromance Posted November 15, 2015 Share Posted November 15, 2015 Have you had a look at Hython? Comes installed with Houdini. Example: in the shell: hython script.py script.py contents: import shutil #copy hip template into another directory newfile = ‘/path/to/my/hip/file/newhipfile.hip’shutil.copy('/dir/file.hip', newfile) hou.hipFile.load(newfile)hou.node("/path/to/driver").pressButton() Quote Link to comment Share on other sites More sharing options...
