Displacement "edges" problem
Hi everybody!
I have a problem with displacement map.
I have a static geometry with UV, static camera and static lights, but between frames the displacement seems animated, only in edges. It's a very tiny detail, but very annoying in render sequences.
I tried to:
-increase displacement in ranges from 0.001 to 0.005, with his bounds
-use PBR renderer, increasing pixel samples to 35 and max ray samples to 20
-render it to 50% and 100%
-use simple displacement shader with UV map displacement and procedural noise displacement
I have another pieces with the same problem.
Any solution?
Thanks in advance!
Files:
https://www.dropbox.com/sh/r4vmfi8awviqa4d/AADade-xCfLS_bpMimzFEzVpa?dl=0
PD: sorry if there are a post with this problem (I searched it but I didn't find)
Displacement_problem.hipFetching info...
Edited by Cuenk89
  • 1 month later...
