Orient object along velocity vector
dchow1992
Hey everyone,
Trying to make more sense out of matrices and quaternions; Having some trouble
orienting a sphere along its velocity vector. Some of it is starting to make sense..but I get
lost pretty fast.
right now I am taking the vel and creating a coordinate system around it and then using the orient vop.
Not sure my setup is proper and am getting weird popping at some points.
Thanks for checking it out,
David
orient_odforce.hipnc
just subtract center from P before orient
since now you are rotating geo, (that's already animated) around 0,0,0 then adding another center offset
and what you want is move geo to center(by subtracting), then rotate around 0,0,0, then add center offset back
