VEX: Is Point Inside Geometry
galagast
I don't think so. You would have to find the closest spot on any primitive with XYZDistVOP, evaluate N attribute at this point with Primitive attribute VOP and check with dot product if hit vector (from point in question to hit position) and evaluated normal have the same orientation. If they are opposite, you are outside an object, inside otherwise.
  • Like 4
  • 4 years later...
  • 1 year later...
