how to test custom VEX shaders ?
spice
try this with vcc
vcc -l hair.otl -N "VEX Hair" hair.vfl
replace hair with your own name for your shader.
This will make an .otl file which can be imported into Houdini through the file menu option "Install Operator Type Library..."
It should then be available to use as a shader in a shop network.
try this with vcc
15669[/snapback]
All right.... :) Thanks !!!!
