How to import one shader into another shader for use in layer mix
HI,
I have 2 shaders, a Mantra Surface Shader and a Principled Shader. I'd like to import the Principled Shader into the MSS for use in a LayerMix, analogous to using an Object Merge in SOPs.  In short, is there a "Shader Merge" out there?
Thanks!
