Strooja Posted December 5, 2015 Share Posted December 5, 2015 Hi Guys, can anybody explain me, how i set my goal_twist_axis in sop?? I use houdin 15 I create a attribute vop and for example i connect a "parameter node" with a "add attribute node".i call the attribute "goal_twist_axis" ,the Local variable name is GOAL_TWIST_AXIS. Attribute class is primitive and type info is normal. The parameter node output is vector. In the spreadsheet everthing looks good.But it has no effect for the constraint in the dop. I hope anybody can help me.That would be great. Quote Link to comment Share on other sites More sharing options...
sekow Posted December 6, 2015 Share Posted December 6, 2015 its hard to say without an hipfile Quote Link to comment Share on other sites More sharing options...
