Stick RBD Packed to transforming object
stevegh
So I believe this is a very simple thing to solve, and I may be setting it up completely wrong....
In the sample attached I have an RBD packed object that falls onto a grid and at frame 24 I group those packed points using a bounding box in a sop solver, and set the active value to 0. I then use the active value to switch solvers from RBD over to a geo wrangle where I just want the points to follow the transform of the grid at /obj level. The problem is that DOPs is grabbing the geometry from the previous frame and results in compounding transforms. How can I just have these points stop being solved?
Thanks in advance!
-S
stickInactive.001.hip
