yamanash Posted December 12, 2015 Share Posted December 12, 2015 (edited) Hey guys, I am having a heck of a time getting my farm setup for my school finals. I have three machines I need to run sliced fluid sims on. Right now I am just trying to get the main workstation to complete a HQueue job... So I have HQueue client and server installed on this machine on the C drive. Both services run fine under another admin account I created called HQueue. I Have used the shelf tool for creating a sliced sim (pyro sim in this case) as recommended per the HQueue documentation. The shared folder with a houdini install in it is on another disk called F in the workstation, the specific folder is shared as hq to all other machines and is mounted on all of them as H: I have no problems accessing it from any machine. The server's .ini file has been setup with the server ip of the pc it is running on (the workstation), and these lines have been set: hqserver.sharedNetwork.path.windows = \\KYLE-PC\hq hqserver.sharedNetwork.mount.windows = H: Everything else in there is vanilla. The problem seems to be in writing the slice files to the mounted H: drive, as I get this error when I submit the houdini file I have attached: hqlib.callFunctionWithHQParms(hqlib.simulateSlice) File "\\KYLE-PC\hq\houdini_distros\hfs.windows-x86_64\houdini\scripts\hqueue\hqlib.py", line 1864, in callFunctionWithHQParms return function(**kwargs) File "\\KYLE-PC\hq\houdini_distros\hfs.windows-x86_64\houdini\scripts\hqueue\hqlib.py", line 1532, in simulateSlice _renderRop(rop) File "\\KYLE-PC\hq\houdini_distros\hfs.windows-x86_64\houdini\scripts\hqueue\hqlib.py", line 1869, in _renderRop rop.render(*args, **kwargs) File "//KYLE-PC/hq/houdini_distros/hfs.windows-x86_64/houdini/python2.7libs\hou.py", line 32411, in render return _hou.RopNode_render(*args, **kwargs) hou.OperationFailed: The attempted operation failed. Error: Failed to save output to file "H:/projects/geo/untitled.loadslices.1.bgeo.sc". Error: Failed to save output to file "H:/projects/geo/untitled.loadslices.2.bgeo.sc". I am really not sure why this is happening as I think I have all the relevant permissions. Any suggestions peeps? -KyleHere is the diagonostics ouput too:Diagnostic Information for Job 75:==================================Job Name: Simulate -> HIP: untitled.hip ROP: save_slices (Slice 0)Submitted By: KyleJob ID: 75Parent Job ID(s): 73, 76Number of Clients Assigned: 1Job Status: failedReport Generated On: December 12, 2015 01:52:08 AMJob Properties:===============Description: NoneTries Left: 0Priority: 5Minimum Number of Hosts: 1Maximum Number of Hosts: 1Tags: singleQueue Time: December 12, 2015 01:15:04 AMRunnable Time: December 12, 2015 01:46:19 AMCommand Start Time: December 12, 2015 01:50:04 AMCommand End Time: Start Time: December 12, 2015 01:50:04 AMEnd Time: December 12, 2015 01:50:18 AMTime to Complete: 13sTime in Queue: 35m 00sJob Environment Variables:==========================HQCOMMANDS:{ "hythonCommandsLinux": "export HOUDINI_PYTHON_VERSION=2.7 && export HFS=\"$HQROOT/houdini_distros/hfs.$HQCLIENTARCH\" && cd $HFS && source ./houdini_setup && hython -u", "pythonCommandsMacosx": "export HFS=\"$HQROOT/houdini_distros/hfs.$HQCLIENTARCH\" && $HFS/Frameworks/Python.framework/Versions/2.7/bin/python", "pythonCommandsLinux": "export HFS=\"$HQROOT/houdini_distros/hfs.$HQCLIENTARCH\" && $HFS/python/bin/python2.7", "pythonCommandsWindows": "(set HFS=!HQROOT!\\houdini_distros\\hfs.!HQCLIENTARCH!) && \"!HFS!\\python27\\python2.7.exe\"", "mantraCommandsLinux": "export HFS=\"$HQROOT/houdini_distros/hfs.$HQCLIENTARCH\" && cd $HFS && source ./houdini_setup && $HFS/python/bin/python2.7 $HFS/houdini/scripts/hqueue/hq_mantra.py", "mantraCommandsMacosx": "export HFS=\"$HQROOT/houdini_distros/hfs.$HQCLIENTARCH\" && cd $HFS && source ./houdini_setup && $HFS/Frameworks/Python.framework/Versions/2.7/bin/python $HFS/houdini/scripts/hqueue/hq_mantra.py", "hythonCommandsMacosx": "export HOUDINI_PYTHON_VERSION=2.7 && export HFS=\"$HQROOT/houdini_distros/hfs.$HQCLIENTARCH\" && cd $HFS && source ./houdini_setup && hython -u", "hythonCommandsWindows": "(set HOUDINI_PYTHON_VERSION=2.7) && (set HFS=!HQROOT!\\houdini_distros\\hfs.!HQCLIENTARCH!) && (set PATH=!HQROOT!\\houdini_distros\\hfs.!HQCLIENTARCH!\\bin;!PATH!) && \"!HFS!\\bin\\hython\" -u", "mantraCommandsWindows": "(set HFS=!HQROOT!\\houdini_distros\\hfs.!HQCLIENTARCH!) && \"!HFS!\\python27\\python2.7.exe\" \"!HFS!\\houdini\\scripts\\hqueue\\hq_mantra.py\""}HQPARMS:{ "controls_node": "/obj/pyro_sim/DISTRIBUTE_pyro_CONTROLS", "dirs_to_create": [ "$HIP/geo" ], "tracker_port": 54534, "hip_file": "$HQROOT/projects/untitled.hip", "output_driver": "/obj/distribute_pyro/save_slices", "enable_perf_mon": 0, "slice_divs": [ 1, 1, 1 ], "tracker_host": "KYLE-PC", "slice_num": 0, "slice_type": "volume"}HQHOSTS:KYLE-PCJob Conditions and Requirements:================================hostname any KYLE-PCExecuted Client Job Commands:=============================Windows Command:(set HOUDINI_PYTHON_VERSION=2.7) && (set HFS=!HQROOT!\houdini_distros\hfs.!HQCLIENTARCH!) && (set PATH=!HQROOT!\houdini_distros\hfs.!HQCLIENTARCH!\bin;!PATH!) && "!HFS!\bin\hython" -u "!HFS!\houdini\scripts\hqueue\hq_sim_slice.py"Client Machine Specification (KYLE-PC):=======================================DNS Name: KYLE-PCClient ID: 1Operating System: windowsArchitecture: x86_64Number of CPUs: 24CPU Speed: 4000.0Memory: 25156780Client Machine Configuration File Contents (KYLE-PC):=====================================================[main]server = KYLE-PCport = 5000sharedNetwork.mount = \\KYLE-PC\hq[job_environment]HQueue Server Configuration File Contents:==========================================## hqserver - Pylons configuration## The %(here)s variable will be replaced with the parent directory of this file#[DEFAULT]email_to = you@yourdomain.comsmtp_server = localhosterror_email_from = paste@localhost[server:main]use = egg:Paste#httphost = 0.0.0.0port = 5000[app:main]# The shared network.hqserver.sharedNetwork.host = KYLE-PChqserver.sharedNetwork.path.linux = %(here)s/sharedhqserver.sharedNetwork.path.windows = \\KYLE-PC\hqhqserver.sharedNetwork.path.macosx = %(here)s/HQSharedhqserver.sharedNetwork.mount.linux = /mnt/hqhqserver.sharedNetwork.mount.windows = H:hqserver.sharedNetwork.mount.macosx = /Volumes/HQShared# Server port number.hqserver.port = 5000# Where to save job outputjob_logs_dir = %(here)s/job_logs# Specify the database for SQLAlchemy to usesqlalchemy.default.url = sqlite:///%(here)s/db/hqserver.db# This is required if using mysqlsqlalchemy.default.pool_recycle = 3600# This will force a thread to reuse connections.sqlalchemy.default.strategy = threadlocal########################################################################## Uncomment these configuration values if you are using a MySQL database.########################################################################## The maximum number of database connections available in the# connection pool. If you see "QueuePool limit of size" messages# in the errors.log, then you should increase the value of pool_size.# This is typically done for farms with a large number of client machines.#sqlalchemy.default.pool_size = 30#sqlalchemy.default.max_overflow = 20# Where to publish myself in avahi# hqnode will use this to connectpublish_url = http://hostname.domain.com:5000# How many minutes before a client is considered inactivehqserver.activeTimeout = 3# How many days before jobs are deletedhqserver.expireJobsDays = 10# The maximum number of jobs (under the same root parent job) that can fail on# a single client before a condition is dynamically added to that root parent# job (and recursively all its children) that excludes the client from ever# running this job/these jobs again. This value should be a postive integer# greater than zero. To disable this feature, set this value to zero.hqserver.maxFailsAllowed = 5# The priority that the 'upgrade' job gets.hqserver.upgradePriority = 100use = egg:hqserverfull_stack = Truecache_dir = %(here)s/databeaker.session.key = hqserverbeaker.session.secret = somesecretapp_instance_uuid = {fa64a6d1-ae3f-43c1-8141-9c29fdd9d418}# Logging Setup[loggers]keys = root[handlers]keys = console[formatters]keys = generic[logger_root]# Change to "level = DEBUG" to see debug messages in the log.level = INFOhandlers = console# This handler backs up the log when it reaches 10Mb# and keeps at most 5 backup copies.[handler_console]class = handlers.RotatingFileHandlerargs = ("hqserver.log", "a", 10485760, 5)level = NOTSETformatter = generic[formatter_generic]format = %(asctime)s %(levelname)-5.5s [%(name)s] %(message)sdatefmt = %B %d, %Y %H:%M:%SJob Status Log:===============December 12, 2015 01:15:04 AM: Assigned to KYLE-PC (master)December 12, 2015 01:15:10 AM: setting status to runningDecember 12, 2015 01:15:23 AM: setting status to failedDecember 12, 2015 01:18:28 AM: Rescheduling...December 12, 2015 01:18:28 AM: setting status to runnableDecember 12, 2015 01:18:28 AM: Assigned to KYLE-PC (master)December 12, 2015 01:18:35 AM: setting status to runningDecember 12, 2015 01:18:47 AM: setting status to failedDecember 12, 2015 01:23:18 AM: setting status to runnableDecember 12, 2015 01:23:19 AM: Assigned to KYLE-PC (master)December 12, 2015 01:23:20 AM: setting status to runningDecember 12, 2015 01:23:33 AM: setting status to failedDecember 12, 2015 01:29:44 AM: setting status to runnableDecember 12, 2015 01:29:44 AM: Assigned to KYLE-PC (master)December 12, 2015 01:29:44 AM: setting status to runningDecember 12, 2015 01:29:57 AM: setting status to failedDecember 12, 2015 01:34:17 AM: setting status to runnableDecember 12, 2015 01:34:17 AM: Assigned to KYLE-PC (master)December 12, 2015 01:38:17 AM: setting status to abandonedDecember 12, 2015 01:46:19 AM: setting status to runnableDecember 12, 2015 01:50:04 AM: Assigned to KYLE-PC (master)December 12, 2015 01:50:04 AM: setting status to runningDecember 12, 2015 01:50:18 AM: setting status to failed UPDATE: I just did a system restart to see if it would help and instead of the regular write error I recieved this:0x00000000577CDE78 (0x000000000000002B 0x000000AD63AEF840 0x000000AD453FEEB0 0x0000000000000000), ?thread_sleep_v3@internal@tbb@@YAXAEBVinterval_t@tick_count@2@@Z() + 0x8C8 bytes(s)0x00000000577CDD2B (0x000000AD45381F90 0x000000AD45381F90 0x000000AD453FEEB0 0x0000000000000000), ?thread_sleep_v3@internal@tbb@@YAXAEBVinterval_t@tick_count@2@@Z() + 0x77B bytes(s)0x00007FFF29E43FEF (0x00007FFF29EE1DB0 0x0000000000000000 0x0000000000000000 0x0000000000000000), _beginthreadex() + 0x107 bytes(s)0x00007FFF29E44196 (0x00007FFF29E44094 0x000000AD453FEEB0 0x0000000000000000 0x0000000000000000), _endthreadex() + 0x192 bytes(s)0x00007FFF36582D92 (0x00007FFF36582D70 0x0000000000000000 0x0000000000000000 0x0000000000000000), BaseThreadInitThunk() + 0x22 bytes(s)0x00007FFF36C29F64 (0x0000000000000000 0x0000000000000000 0x0000000000000000 0x0000000000000000), RtlUserThreadStart() + 0x34 bytes(s) After resubmission, it went back to the usual error mentioned above. untitled.hip Edited December 12, 2015 by yamanash Quote Link to comment Share on other sites More sharing options...
yamanash Posted December 13, 2015 Author Share Posted December 13, 2015 \\KYLE-PC\hq was the issue, should have used forward slashes... That's what I get for writing that line at 3 am lol... cheers. Quote Link to comment Share on other sites More sharing options...
