wilson99 Posted December 14, 2015 Share Posted December 14, 2015 (edited) Hi Houdini 14/15 scatter node is slightly different to 13. I understand there was a thread about this talking about the Attribute Bias option but what if you're scattering points within your geo/volume and not on the surface. https://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&t=37345&highlight=&sid=7851375fa44ef5f63c8fa9aa751b4cfe It used to be you IsoOffset and the Scatter node would pick up on it. Any ideas? EDIT: Point Jitter does have some use but does have its limitations Edited December 14, 2015 by wilson99 Quote Link to comment Share on other sites More sharing options...
wilson99 Posted December 14, 2015 Author Share Posted December 14, 2015 (edited) Solutions Point Jitter does have some use but does have its limitations Best results is simply with an IsoOffset and using the Position (P) as the Density Attribute. Might have rushed a but too much with this question, sorry guys Edited December 14, 2015 by wilson99 Quote Link to comment Share on other sites More sharing options...
