Dexter Posted December 15, 2015 Share Posted December 15, 2015 HI, guys. I tried to use image sequence as my background. I tried to type in name_$F3.jpg. But I can only see my first frame. Is any one knows why this happened? Quote Link to comment Share on other sites More sharing options...
henrik.g Posted December 15, 2015 Share Posted December 15, 2015 Does your timeline have the same timecode as the image sequence? Also take a look if Houdini did not by itself reverted this to a single Digit. This happens to me sometimes, I just witch it back to $FX again. Quote Link to comment Share on other sites More sharing options...
Dexter Posted December 15, 2015 Author Share Posted December 15, 2015 Timeline? Where should I write the code to change the timeline? I never used that. So I don't know where is it. Quote Link to comment Share on other sites More sharing options...
henrik.g Posted December 15, 2015 Share Posted December 15, 2015 If your Image Sequence for example as been retimed and starts at 1001 then your Houdini Timeline has to correspond to that. In the lower Right corner you can set the beginning and End of the timeline. Quote Link to comment Share on other sites More sharing options...
