rawks Posted December 19, 2015 Share Posted December 19, 2015 Hi all, I'm trying to create a ramp in VOP to drive an attribute that will drive another simulation. Works fine for X axis but I'm totally confused about how to use the same technique, or similar one to put my ramp on Y axis. File to explain is attached. Thank to everyone will help me with this simple thing. E. YRamp.hipnc Quote Link to comment Share on other sites More sharing options...
mestela Posted December 20, 2015 Share Posted December 20, 2015 Move your vecToFloat to before the ramp. See how in your setup there's a dashed line connecting P to the ramp? That's a warning to tell you you're connecting different types together. P is a vector, but the ramp takes a float. It's doing a naive type conversion for you, so P becomes P.x. By moving the vecToFloat to sit between P and the ramp, you can explicitly control the conversion. Connect the 2nd output of vecToFloat to the ramp, you'll be controlling your setup with P.y. Quote Link to comment Share on other sites More sharing options...
rawks Posted December 20, 2015 Author Share Posted December 20, 2015 Thank you for your reply, you have solved my problem! I have attached the correct file, maybe could be useful for someone. However, I want to go in deep with this. At the moment looking spreadsheet and colours on my monitor I haven`t a full scale from black to white (so from 0,0,0 to 1,1,1), i have tried to add another fit range before the 'visualize colour node' but it doesn't work! Thank you, E. YRamp_Corrected.hipnc Quote Link to comment Share on other sites More sharing options...
mestela Posted December 21, 2015 Share Posted December 21, 2015 Similar answer to before, gotta put the fit range in the right place. A ramp parameter assumes whatever is driving it is between 0 and 1, anything above and below that will be clipped. In your existing setup, look at the geometry spreadsheet and click on the P[y] column to sort it. The values go from -0.5 to 0.5. You have a cylinder of length 1, but its centered on the origin. To fix this to make the ramp work as expected, put the fit range after the vecToFloat, and before the ramp. You then set it so that the input range is -0.5 , 0.5, and the output range is 0,1. Helps to add a few divisions on the cylinder too, to ensure it's all doing the right thing. YRamp_Corrected2.hipnc Quote Link to comment Share on other sites More sharing options...
rawks Posted December 21, 2015 Author Share Posted December 21, 2015 Hey Matt, Cool, your explanation has been really easy and useful. For what I have understood the fit node is related also to the position of the object in the space in this case, so moving the object will affect also his colour. Just solved this applying transform node after vopsop. Thanks again Matt, big up E. Quote Link to comment Share on other sites More sharing options...
