yingfeizhou Posted December 20, 2015 Share Posted December 20, 2015 There is some black under the glass when I used the envlight to render。I think it is shadow of the envlight,but why? It is all right in maya when I used other renderers for example vray。 what can I do ? Quote Link to comment Share on other sites More sharing options...
OskarSwierad Posted December 20, 2015 Share Posted December 20, 2015 Could you post the scene file? Quote Link to comment Share on other sites More sharing options...
yingfeizhou Posted December 20, 2015 Author Share Posted December 20, 2015 here the scene file. thank you ! glass_mat.rarFetching info... Quote Link to comment Share on other sites More sharing options...
woodenduck Posted December 20, 2015 Share Posted December 20, 2015 I had errors on the shaders when I opened your file (are they custom or from an old Houdini?), so I replaced them with a default glass material and a vanilla mantra surface shader just with your wood texture added in the colour map parm. I got this... glass_WD.hipFetching info... Quote Link to comment Share on other sites More sharing options...
yingfeizhou Posted December 23, 2015 Author Share Posted December 23, 2015 The result I used the caustic light to render the glass. Quote Link to comment Share on other sites More sharing options...
