Rore Posted December 29, 2015 Share Posted December 29, 2015 Hi everyone, PROBLEM: no interraction between flip and Fracture object WHAT I DID: i create a flip tank, 1 cube shattered falling apart into the flip tank, and another cube falling straight into the tank. The problem is, when i make a cube fall as it is, the interaction are great, but from this cube are shattered and turn into dynamic piece, they are no more interaction. Anyone have any ideas ?I used houdini 13 (because of a lack of ressources)I linked the scene files, if u want to have a look.Thanks a bunch test.hip Quote Link to comment Share on other sites More sharing options...
John Svensson Posted January 3, 2016 Share Posted January 3, 2016 One suggestion that comes to mind is to make sure that your collision geometry is a good representation of the fractured cube, and that you have proper velocity vectors on the fractures Quote Link to comment Share on other sites More sharing options...
damkhuman Posted January 3, 2016 Share Posted January 3, 2016 Hi Rore, I have checked your file and I am not sure whether packed prim interacts with flip yet or not but if you use "rbd fractured object" it will interact as you expect. Would like to know if there is a way to interact packed prim with flip directly. test_fixed.hip Quote Link to comment Share on other sites More sharing options...
