Setting up Packed Primitives
aley
Hi I was wondering if somoene could lend me some help, still learning houdini and running ito a bit of a wall today, I have some fractured Geometry theat I have fractured by using a tace sop then extruding the fractured geo and using a partition sop to seperate the pieces. Now I would like to pack these objects so I can use them in a packe rbd sim, like how I woudl with a voroni fracture,
I know the assemble sop packs pieces using the attribute "piece" name for the voroni fracture but when I try and create this attribute on my fractured geo and then pack using the assmble sop I just get one object that acts as one piece in a pack rbd sim.
any help with this would be great or even better a samll example scene if anoyone has that.
may thanks in advance.
Alex.
thanks for the reply I have tried that, still not working I think the issue may be I dont have sepearte islands maybe but when I use the esplode view node I does seperate correctly.
Ive tried usingh the conectivity and partition sop to to seperate but still no luck.
