lighting model node in Houdini 15
Hi, guys, I am new to houdini and I was a little bit confused that I can not find the lighting model node in material builder in houdini 15. Has it been hide by side effects?Which node I can use to replace it? Thank you very much!
are you following an old tutorial or something?  lighting model is probably hidden (if not completely removed) as it's pretty old and predates pbr (i think).  current tech is "surface model" vop.
Got it, thank you very much
The lighting model did support pbr and was the only way of creating an isotropic volume bsdf in vops that I know of.  In vex you can just use isotropic() function of course.
You can still create a lighting model vop by typing 'opadd lighting' in the textport.
