flipbook spazzing out
cgcris
Hi guys,
Having an issue when flipbooking stuff, currently on windows 7 and H15. I've tried it with different setups and it's always the same issue.
The flipbook generally messes up the initial 10-30 frames, it's almost like it goes to fast and doesn't capture the viewport correctly.
Any ideas what this could be or how to fix this?
Thanks,
Cris
which version of 15?  initial release does this, but by 313 it's fixed.  the problem is when it's bouncing back and forth between the viewport and mplay as mplay is launching and grabbing the cached frames -- it seems to get confused.  the solution (aside from updating houdini) is to leave your flipbook mplay open and then re-flipbook and it'll be fine.
