Change data directly in Geometry spreadsheet?
cwalrus
You CAN do this if you drop a point sop first and select the point sop, then box select cells in the the Geo Spreadsheet. This will also lock the point sop and thus break proceduralism, which is usually less than ideal.
I feel like this workflow should generally be avoided, but it is definitly doable.
