Editing parameter interface makes Houdini crash.
thibh
Hi guys,
I'm currently facing a really strange crash when trying to add controls to a null object.
I have no problem adding custom float sliders or menus, but Houdini crashes whenever I try to add interface parameters from other nodes (segmentation fault error).
I tried deleting my preferences, but nothing will do.
I can always add the parameters by hand and link them afterwards manually to the specific nodes inside my network but this is really time consuming.
Do you have any idea why this crash happens ?
Thanks for your help!
Thibault.
Edited by thibh
I finally found a solution for this problem while watching a tutorial.
I didn't know you could just drag and drop parameters from the parameters tabs directly onto the existing parameters interface, removing the need to go into the "From Nodes" tab which made Houdini crash.
Edited by thibh
