Baram Posted February 4, 2016 Share Posted February 4, 2016 Hello Friends sbd spring constrain does it work with rbdpackedobj ? I have tried seem just work with fractured obj in dop Is anyone know what is the solution? Thank you B, Quote Link to comment Share on other sites More sharing options...
goldleaf Posted February 7, 2016 Share Posted February 7, 2016 No it doesn't, but what you can do is swap out the type of constraint being used. Assuming you're using the shelf tools, go to your AutoDopNetwork, and change the node called glue_constraint (which is a Glue Constraint Relationship DOP) with a Spring Constraint Relationship DOP node. Now, you need to set the Spring's Data Name to Glue, since that's what the constraint setup is looking for. Now it's a matter of adjusting the strength/damping as desired (and probably have to increase constraint iterations on the solver). Hope that helps! spring_glue_network.hipnc Quote Link to comment Share on other sites More sharing options...
Baram Posted February 7, 2016 Author Share Posted February 7, 2016 Hi Goldleaf, Thank you for the instruction and hip file, Actually It's not what I want but good to know this. I want to connect selected two piece and give them a movement in certain frames, like active it in only for first 4 frames.. Cheers, B, Quote Link to comment Share on other sites More sharing options...
