Curl noise in Dops
ITdreamer
I know about POP Force in DOPs. You mean that POP Force in DOPs and the Curl Noise in old POPs are the same?
In old POPs there were Force POP where you could add noise and Curl Noise POP. Noise in Force POP and the Curl Noise give different results.
I guess that the Curl Noise is not exist in the DOP Context is because of the nature of the DOP Context.
Edited by ITdreamer
Curl Noise exists in the Dop context. Bifrost is correct.
Drop down a POP Network - Old, Curl Noise. Dive into Curl Noise > voppop1. Find Curl Noise vop called curlnoise1
Now back out and drop down a Dop Network > POP Force. Dive into Pop Force > noise_force > curl_noise. Inside curl_noise find the vop Curl Noise called curlnoise1.
Same exact node, different packaging.
