Edge Reduction
galagast
Hi, is there a built-in way to reduce points on edges via an angle threshold?
post-3610-0-08252300-1456292589_thumb.jp
I was able to resolve this using a Point Wrangle:
int id_next = @ptnum+1 > @numpt-1 ? 0 : @ptnum+1;
vector p_next = point(0, "P", id_next);
vector p_last = point(0, "P", @ptnum-1);
vector v1 = normalize(p_last - @P);
vector v2 = normalize(p_next - @P);
float rad = dot(v1, v2);
f@ang = degrees(acos(rad));
int val = @ang > ch("thresh");
setpointgroup(0, "flat", @ptnum, val, "set");
It creates a "flat" group that I would then blast. Although this would only work on very specific cases. >_<
I was just curious if there's another method to do this natively?
these do work great, but unfortunately neither of those allow you set anchor points (points it will never remove)
for very small tolerances these methods work great though.
If anyone knows an easy way to set anchor points as well, I would be interested in that.
Its possible to just write a custom version of the node in a attrib wrangle,
but if there was an easier way by say passing point groups into the facet node that would have been great.
The Facet SOP does have a Group parameter that allows point groups.. unless I misunderstood something from your query. :lol:
post-3610-0-86163200-1456305940_thumb.jp
Edited by galagast
well yeah it does accept them, but it doesn't do anything with them in relation to "Remove Inline Points" as far as I know (at least in H14) :P
if I say, put: "!pointgroupSomething" in the groupfield, it can still remove those points with the "Remove Inline Points", correct me if Im wrong
Initial solution naturally works for group selection. Alternative version:
int nbs[] = neighbours(0, @ptnum);
if (len(nbs) == 2)
    vector a = normalize(point(0, "P", nbs[0]) - @P);
    vector b = normalize(point(0, "P", nbs[1]) - @P);
    float inlinity = fit11(dot(a, , 1, 0);
    if (inlinity > ch("max_inlinity"))
        removepoint(0, @ptnum);
remove_inline.hipnc
Edited by f1480187
