Retrieving a detail attribute
Guest xionmark
Guest xionmark
Hi there,
I'm having problems retrieving a detail attribute (float, vector, string, etc.). I can create and retrieve point, primitive and vertex attributes and can create detail attributes (all verified in the spreadsheet) but for some reason I can't seem to be able to retrieve detail attribute offsets and thus the attribute values.
I have tried the different variants of findAttrib() & findAttribute(), for example:
int sd_CG_pos = gdp->findAttrib("sd_CG_pos", 3, GB_ATTRIB_VECTOR);
if(sd_CG_pos >= 0)
UT_Vector3 *CG_pos = (UT_Vector3 *)gdp->attribs().getAttribData(sd_CG_pos);
but I always get a -1 returned from the findAttrib() & findAttribute() calls.
ANother question: for a string detail attribute, what would one use for the "size" argument? I assumed 1 to represent "one string", but also tried the call without the size arg, no difference, they always return a -1 for the offset value (meaning it can't find the attribute):
int obj_tex_fname = gdp->findAttribute("sd_obj_tex_fname", 1, GB_ATTRIB_STRING, GEO_DETAIL_DICT);
-OR-
int obj_tex_fname = gdp->findAttrib("sd_obj_tex_fname", GB_ATTRIB_STRING);
Suggestions? Example?
Thanks!
-Mark
This is a code snip from one of ours which works somehow:
int instance_attr_offset = centroids->pointAttribs().append("break_instance",sizeof(int),GB_ATTRIB_INDEX,"");
GB_Attribute *atr = centroids->pointAttribs().find("break_instance");
Guest xionmark
Hi Jason,
Thanks for the example. It got me going down another path but ran into a wall. I can now find the detail attribute and find out what type it is (though I still don't know how to deal with strings yet) but when trying to find the offset to retrieve the data, it still returns a -1. This is true when looking for float, int, vector and string attributes.
myGB_Attr = gdp->attribs().find("sd_obj_tex_fname");
if(myGB_Attr) {
cout << "getType: " << myGB_Attr->getType() << endl;
cout << "getTypeInfo: " << myGB_Attr->getTypeInfo() << endl;
cout << "getName: " << myGB_Attr->getName() << endl;
cout << "getSize: " << myGB_Attr->getSize() << endl;
cout << "getAllocSize: " << myGB_Attr->getAllocSize() << endl;
cout << "getIndex: " << myGB_Attr->getIndex("sd_obj_tex_fname") << endl;
cout << "getIndexSize: " << myGB_Attr->getIndexSize() << endl;
example output:
getType: 4
getTypeInfo: 0
getName: sd_obj_tex_fname
getSize: 4
getAllocSize: 4
getIndex: -1
getIndexSize: 1
So how is one supposed to get the index offset from a GB_Attribute object?
Still puzzled :blink:
--Mark
  • 3 weeks later...
hmm.. I know I saw some back and forth about attributes on the mailing list a while back, so if this has already been answered, please ignore (I should really pay more attention to my e-mails).
If not, I believe you're using the wrong value for size. Size, AFAIK, is the memory footprint, so you should use th result of sizeof, i.e.:
int fooOffset = gdp->findPointAttrib("foo", sizeof(int), GB_ATTRIB_INT);
.. or sizeof(UT_Vector4), etc.
as far as strings go, string attribs are indexed attributes - stored in the gdp and referenced by integer index, so size for the string would, again, be sizeof(int).
If you'd like a code example, I'll post one here. let me know.
::edited to add:: well, it appears this has all been answered in another thread. say la vee. hehe ;)
