create piece size attribute
Gubkin
Hello everyone,
I am fracturing a geometry and need to delete the pieces bellow a certain size. My problem is that I don't know how to delete based on size. My guess is I need to create a size attribute somehow and then delete based on that. I am sure this should be pretty straight forward but couldn't find any info on that, please give me some ideas, thanks!
you can run a foreach on each piece, then use the measure sop to calculate the area of each poly then attribute promote to a detail attribute by summing the areas.  check the value of that detail attribute to decide what to do -- or maybe just stuff that value onto each prim.
alternatively, you might be able to calculate the area of a polysoup as a single prim  -- not sure.  so you'd run your foreach, convert to polysoup and measure that as a single prim without the attribute promote....
Edited by fathom
