POP Wrangle created attributes not showing up correctly in geometry sp
Hey guys,
I'm currently struggling with attributes showing up correctly in the geometry tab of geometry spreadsheet. Doesn't matter if I try to edit existing attributes like @pscale or try to create custom attributes. They always show up with a 0 or 0.0 value depending if I exported an integer or float attribute. So that shows that I'm exporting it, but it doesn't show the value correctly. Troubleshooting without the details view/geometry spreadsheet is really difficult.
I'm grateful for every answer.
Make shure you have the node selected and that your spreadsheet is set to "Follow Selection". I assume you are adding pscale inside the POP-net. How are you exporting particles to SOP's?
Might help if you submit your scenefile since this normally should work.
Dennis
