mstarktv Posted April 8, 2016 Share Posted April 8, 2016 Still new to Houdini, but I ran into something interesting(for me) when I was trying to just take the idea of deleting particles based on their Y value. This seemed to work fine until I turned my points into solids. When I was using points, in my dop network I used a geometry wrangle node with the following condition to kill particles below a certain Y value: if(@P.y<-.25) removepoint(0, @ptnum); Now, when I try this with baked geometry that has been converted to solids and using a finite element solver, I can't seem to get the same results. This is where I'm lost. I'm assuming, it's because the solids are now no longer points. But I don't know how to access them for deletion. I attached a file with a simple setup if you're curious to take a look. I'm just taking the idea of deleting objects based on Y height and applying it across the board with all solver/object types. Any help is much appreciated! Best, Stark pointScatter.hipnc Quote Link to comment Share on other sites More sharing options...
f1480187 Posted April 8, 2016 Share Posted April 8, 2016 (edited) Tetrahedra are primitives. This should work: if (@P.y < -0.25) { removeprim(0, @primnum, true); } remove_tets.hipnc Edited April 8, 2016 by f1480187 1 Quote Link to comment Share on other sites More sharing options...
mstarktv Posted April 9, 2016 Author Share Posted April 9, 2016 Tetrahedra are primitives. This should work: if (@P.y < -0.25) { removeprim(0, @primnum, true); } Thanks for this. Is there a way that it deletes the entire mesh at once? Even if that involves deleting the particle that is created into the mesh? I see that it deletes each face, but I'm trying to delete the entire mesh at once. On and off, instead of per primitive? Quote Link to comment Share on other sites More sharing options...
mstarktv Posted April 9, 2016 Author Share Posted April 9, 2016 I take that back. I resolved the problem but changing both Group Type a d Run over to Primitives and I got the desired results. Again, thank you Quote Link to comment Share on other sites More sharing options...
